UPDATE: After doing some research it looks like the Beldon 1505 RG59 is the go but here is my post anyway. Doing a live switch in 2 days so hoping for some feedback ASAP. I plan on running SDI 1080 over Beldon RG6 QUAD coax. Commonly my runs will be up to 30M but some will be maybe 60M. I have about 300m of the RG6 left over from a job I did 10 years ago and its in 50 and 100m lengths at present. Its terribly bulky and hard to coil so the option is there to ditch it buy RG59. A tech friend tells me the "strandard Dual Shield" type is the go. Here are my questions; 1. Is RG59 fine for smallers runs say up to 30m? 2. Would joining 2X RG59's meana a possible loss in quality? 3. Is joining a RG59 to a RG6 cable an issue? Based on this video I should be bypassing the quad cable and going for a dedicated SDI cable that has 95% Tin Cooper braid. Thanks in advance, Regards Martin Duffy javascript:__doPostBack('forum$ctl01$PostReply','')
