tdurhamjr
#1 Posted : Wednesday, October 29, 2014 1:06:04 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
I want to make some tutorials on vMix to for some people who help me. I need help figuring out how to setup the desktop capture so that when I am demonstrating vmix, the output window will not continue on an infinate "screen in screen". I have dual monitors. Any guidance will be appreciated. When Martin did his Youtube videos there was no video echo. I want to do the same thing :)
hogwam
#2 Posted : Thursday, October 30, 2014 5:57:57 AM(UTC)
hogwam
Record your screen in something like http://camstudio.org/ rather than vMix capturing the screen
Egriswold
#3 Posted : Thursday, October 30, 2014 1:00:47 PM(UTC)
Egriswold
Was thanked: 34 time(s) in 33 post(s)
I've done this very thing, the trick is to set the recorder to only record screen capture module. then I keep this module collapsed and of course never switch to it keeping it out of the program out window. Example of this in use http://youtu.be/fZGEGZciS9Q?list=UUbs25oyD5bQ7Ei4gYiJqGEg
thanks 1 user thanked Egriswold for this useful post.
richardgatarski on 10/30/2014(UTC)
tdurhamjr
#4 Posted : Thursday, October 30, 2014 2:56:07 PM(UTC)
tdurhamjr
Edward,
That is what I am looking for but I can not get this to work or figure it out. Can you be more specific in the instructions?
Tim
richardgatarski
#5 Posted : Thursday, October 30, 2014 3:59:12 PM(UTC)
richardgatarski
Edward, thanks! Wish I new when I recorded my SmartTitler demo yesterday...
Tim, in Settings/Outputs change Recorder source from Output to the Input you use for screen capture and collapse it.
tdurhamjr
#6 Posted : Thursday, October 30, 2014 4:40:29 PM(UTC)
tdurhamjr
Thanks Richard!! That was the little tid bit I needed :) And thanks again to Edward for your help.
