How to prevent visual echo when using Desktop Capture in vMix??
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
I want to make some tutorials on vMix to for some people who help me. I need help figuring out how to setup the desktop capture so that when I am demonstrating vmix, the output window will not continue on an infinate "screen in screen". I have dual monitors. Any guidance will be appreciated. When Martin did his Youtube videos there was no video echo. I want to do the same thing :)
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
I've done this very thing, the trick is to set the recorder to only record screen capture module. then I keep this module collapsed and of course never switch to it keeping it out of the program out window. Example of this in use http://youtu.be/fZGEGZciS9Q?list=UUbs25oyD5bQ7Ei4gYiJqGEg
 1 user thanked Egriswold for this useful post.
Egriswold wrote:I've done this very thing, the trick is to set the recorder to only record screen capture module. then I keep this module collapsed and of course never switch to it keeping it out of the program out window. Example of this in use http://youtu.be/fZGEGZciS9Q?list=UUbs25oyD5bQ7Ei4gYiJqGEg Edward, That is what I am looking for but I can not get this to work or figure it out. Can you be more specific in the instructions? Tim
Edward, thanks! Wish I new when I recorded my SmartTitler demo yesterday...
Tim, in Settings/Outputs change Recorder source from Output to the Input you use for screen capture and collapse it.
Thanks Richard!! That was the little tid bit I needed :) And thanks again to Edward for your help.
