PVP
#1 Posted : Monday, October 27, 2014 9:38:20 AM(UTC)
PVP
Finland
Hi.
How do I edit a source I created?
For example, if I want to lower a title a bit, how do I get back to the settings I do as I create the source? For now, I'm just doing the source from scratch if I do a mistake.
Thanks.
#2 Posted : Monday, October 27, 2014 10:21:07 AM(UTC)
Press the 'reset all button' (as it appears you changed the position of your title) ?
tdurhamjr
#3 Posted : Monday, October 27, 2014 5:56:23 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
PVP wrote:
Hi.
Thanks.
With the Title Preview Window open, double click in the black middle window. That will open up the properties box. Click on the POSITION link on the left. Now you can move the title where ever
you want it to be. I think this is what you were asking.
Tim
tdurhamjr attached the following image(s):
Title Edit 1.jpg (52kb) downloaded 0 time(s).
Title Edit 2.jpg (77kb) downloaded 0 time(s).
PVP
#4 Posted : Tuesday, October 28, 2014 8:49:00 AM(UTC)
PVP
Finland
Well, that was simple. :o
Thanks.
