How do I edit a source I created?
Joined: 9/13/2013(UTC) Posts: 9   Location: home Thanks: 1 times
Hi.
For example, if I want to lower a title a bit, how do I get back to the settings I do as I create the source? For now, I'm just doing the source from scratch if I do a mistake.
Thanks.
Press the 'reset all button' (as it appears you changed the position of your title) ?
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
PVP wrote:Hi.
Thanks. With the Title Preview Window open, double click in the black middle window. That will open up the properties box. Click on the POSITION link on the left. Now you can move the title where ever you want it to be. I think this is what you were asking. Tim tdurhamjr attached the following image(s):  Title Edit 1.jpg (52kb) downloaded 0 time(s). Title Edit 2.jpg (77kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Well, that was simple. :o
Thanks.
