emoutra
#1 Posted : Friday, August 12, 2022 11:32:00 AM(UTC)
emoutra
I'm getting this error message. How do you or can you get the Iriun webcam & Soundcraft notepad 12fx to work with vmix?
vmix screenshot 1.jpg (174kb) downloaded 2 time(s). vmix screenshot 2.jpg (202kb) downloaded 1 time(s).
nikosman88
#2 Posted : Friday, August 12, 2022 6:08:18 PM(UTC)
nikosman88
Greece
Hello. Pc software connects ok with mobile phone? If yes, you can try to use another fps/resolution format. I tried this software cam now for testing and it connects without issue. I tried with samsung galaxy a03s and resolution pal fullhd 25p
emoutra
#3 Posted : Tuesday, August 16, 2022 3:37:41 AM(UTC)
emoutra
The software connects fine. Should I have any audio issues using the soundcraft mixer instead the phones mic?
Similar Topics
Unspecified Error *Solved* (General Discussion)
by stever23 8/1/2020 1:50:19 AM(UTC)
