I'm getting this error message. How do you or can you get the Iriun webcam & Soundcraft notepad 12fx to work with vmix?  vmix screenshot 1.jpg (174kb) downloaded 2 time(s). vmix screenshot 2.jpg (202kb) downloaded 1 time(s).
Hello. Pc software connects ok with mobile phone? If yes, you can try to use another fps/resolution format. I tried this software cam now for testing and it connects without issue. I tried with samsung galaxy a03s and resolution pal fullhd 25p
The software connects fine. Should I have any audio issues using the soundcraft mixer instead the phones mic?
