I am using a HD version (no only one output available).
vMix Call does not allow to choose an input as video feedback in vMix Call. As my output is always the caller, this means i can send him/her back only his/herself, or nothing.
Am i missing another way to achieve this or am i stuck with this limitation ?
Regards.
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
The HD license only gives you one output, so yes you can only use your main program feed / output as the return feed for your vMix Call. You'll need to upgrade to a higher license to be able to send a dedicated return feed
