ptnrs
#1 Posted : Wednesday, August 3, 2022 12:00:45 AM(UTC)
ptnrs
I am using a HD version (no only one output available).
vMix Call does not allow to choose an input as video feedback in vMix Call. As my output is always the caller, this means i can send him/her back only his/herself, or nothing.
Am i missing another way to achieve this or am i stuck with this limitation ?
Regards.
Lennart
#2 Posted : Friday, August 5, 2022 7:20:43 AM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
The HD license only gives you one output, so yes you can only use your main program feed / output as the return feed for your vMix Call. You'll need to upgrade to a higher license to be able to send a dedicated return feed
