BlackMagic Design Micro Converter latency
Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
Does anybody know what the latency is of a BlackMagic Design Micro HDMI to SDI Converter? The search results I've found vary from 1 video line to 1 video frame. I can buy a 2nd hands Sony SRG-300H and want to convert the HDMI output to SDI, but because of a live view application I don't want to add any extra visible latency. Here it is claimed that the latency is only 1 video line.
Joined: 9/10/2015(UTC) Posts: 139  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
It depends on which generation but they're all less than one frame (and typically less than 10 lines).
