JW
#1 Posted : Wednesday, July 27, 2022 5:47:43 AM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
Does anybody know what the latency is of a BlackMagic Design Micro HDMI to SDI Converter?
The search results I've found vary from 1 video line to 1 video frame.
I can buy a 2nd hands Sony SRG-300H and want to convert the HDMI output to SDI, but because of a live view application I don't want to add any extra visible latency.
Here it is claimed that the latency is only 1 video line.
paco3346
#2 Posted : Wednesday, July 27, 2022 10:50:27 AM(UTC)
paco3346
It depends on which generation but they're all less than one frame (and typically less than 10 lines).
