remasterx
#1 Posted : Thursday, July 21, 2022 5:43:09 AM(UTC)
remasterx
Hello everyone !
I had this idea when I was linking a huge google sheet datasource to my gtzip.
It usualy takes me a long time to bind a big amount of data using dropdown lists.
I think it might be much faster to do this using a drag and drop method where the selected Data Source, table, column and row would automatically apply onto a gtzip layer.
It could be a thing like that :
https://prnt.sc/dt4YKTVKcaUL
What do you think ?
#2 Posted : Thursday, July 21, 2022 8:18:23 AM(UTC)
Originally Posted by: remasterx Go to Quoted Post
Hello everyone !
What do you think ?
Please read the documentation: Data sources -> Mapping a data source to a title
Column: Select the column to use for this particular Title Field, if you leave this set to Auto, the data source will map based on the following:
a) Will first look for the first column with the same name as the Title field, for example "Headline"
b) If no column is found, use the column index that matches the Title field index. For example Headline would be Column1, Description Column2 and so on.
Well prepared this will speed up things quit a bit
