Feature Requests
Drag and drop to bind data source to gtzip
Joined: 7/21/2022(UTC) Posts: 1  Location: Levallois Perret
Hello everyone ! I had this idea when I was linking a huge google sheet datasource to my gtzip. It usualy takes me a long time to bind a big amount of data using dropdown lists. I think it might be much faster to do this using a drag and drop method where the selected Data Source, table, column and row would automatically apply onto a gtzip layer. It could be a thing like that : https://prnt.sc/dt4YKTVKcaULWhat do you think ?
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: remasterx  Hello everyone ! I had this idea when I was linking a huge google sheet datasource to my gtzip. It usualy takes me a long time to bind a big amount of data using dropdown lists. I think it might be much faster to do this using a drag and drop method where the selected Data Source, table, column and row would automatically apply onto a gtzip layer. It could be a thing like that : https://prnt.sc/dt4YKTVKcaULWhat do you think ? Please read the documentation: Data sources -> Mapping a data source to a title Quote:Column: Select the column to use for this particular Title Field, if you leave this set to Auto, the data source will map based on the following: a) Will first look for the first column with the same name as the Title field, for example "Headline" b) If no column is found, use the column index that matches the Title field index. For example Headline would be Column1, Description Column2 and so on. Well prepared this will speed up things quit a bit
Feature Requests
