Tonyminsight
#1 Posted : Tuesday, July 19, 2022 6:10:42 AM(UTC)
Tonyminsight
I have my Canon EOS 70D connected through a video capture card. Everything looks good except you can still see the autofocus lines. If I switch to manual focus the lines go away but I would like to use the AF mode.
Has anyone found a way to remove the AF lines in AF mode for a Canon EOS 70D?
Thank you!
paco3346
#2 Posted : Tuesday, July 19, 2022 8:14:34 AM(UTC)
paco3346
What you're looking for is known as a "clean feed". It's really common for DSLRs to not have that mode especially if they weren't intended for live video.
Here's some discussion about your model and clean feed: https://www.dpreview.com/forums/thread/4538735
mjgraves
#3 Posted : Friday, July 22, 2022 1:41:12 AM(UTC)
mjgraves
Only way to get a clean feed from a Canon DSLR is to use the Magic Lantern firmware. (https://magiclantern.fm/) This will void your warranty.
If you use the Canon Webcam app you can get a clean feed into a Windows computer as a virtual webcam. However, the resulting video is something less than 720p30. In particular, the frame rate is not full-rate.
The stream exposed via the USB port is really just the feed to the viewfinder repurposed.
