Showcase
Dutch major league field hockey and Dutch major league ice hockey
Joined: 9/5/2014(UTC) Posts: 2 Location: the netherlands
Its great to work with vMix. We re broadcasting major league field hockey en major league ice hockey in the netherlands. both broadcast we stream through YouTube 720p. Field hockey 3 cams Ice hockey 2 cams we're curious what you guys think about it. Regards Norb
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
Just watched 10mins of the ice hockey game - really like the two camera setup, gives real depth and variety to the coverage. I know how difficult operating a camera at an ice hockey game is, keeping up with the puck - your guys do so very well! Going forward you might want to invest in some gopro cameras, placed behind the goal. Take the HDMI output, in to a HDMI-SDI device and back to vMix. Fix the gopro to the plexiglass with a suction mount and make sure you set it recording (if the device isn't set to record, the output is 4:3. once you hit record, that changes to 16:9) They give some great footage of goals. See video below from my local team highlights from last weekend. (not sure what kit they use for switching) Also maybe put a gopro in each penalty box? Great for cut-aways.
Very nice Norb!
What cameras were you using? Which bitrate? (guess the videos are YouTube's recordings of the live streams)
Hey Howam,
the link you've sent me from the high lights is pretty tight! Looks very good! We're thinking about using GoPro's but im wondering how to connect it while hanging in the goals. as far for the bench and penalty box we can connect it to the hdmi-sdi converter.
@richard gatarski, we using Sony PMW 400's and our bitrate is 4000kbs, it depens whether we can use an internet connection or a wireless usb dongle (4G) since internet is expensive in the netherlands.
Regards
Norb
 1 user thanked SBC for this useful post.
The GoPro's were mounted on the glass behind the goal (not in it) using these type of mounts; http://www.amazon.co.uk/gp/product/B00KU70F6M/The HDMI-SDI converter needs to be at the location of the camera, and run SDI cable from there to the location of your vMix setup hogwam attached the following image(s):  gopro.jpg (302kb) downloaded 28 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
@SBC Have you ever had any problems with youtube copyright violations because of the background music? @hogwam What cameras were you using, besides the Gopros? I have also used Gopros on the plexiglass behind the goals, but it was very frustrating. The camera would either not hold onto the glass or the cables loosen up, so we would have to plug them back in very often. We also tried to mount the gopro with a clamp mount on the top of the glass, which made them a perfect target for the puck... And besides that the video quality was always very disappointing. Very grainy, not really sharp and after a few matches, weird horizontal lines made the picture quality even worse. Maybe I did something wrong, maybe there are some hints for better Gopro live production quality, but from my experience I would say that a Gopro is not a suitable live production camera and in the future I'd rater use something like this: http://www.monacor.co.uk/products/security-cameracolour/vnr/183810/ with a suitable lens.
@Rinsky I'd love to take credit, but that isn't my production!! If the cables keep falling out, perhaps find a way of providing strain relief for the cables, so less force is applied to the socket on the gopro. You may even wish to go as far as using this, moulded around the cables once they are inserted http://www.instamorph.com/
Thanks for the advice!
We tried to use the GoPros (Hero3)once again in our live production, but it failed me again. This time we even had problems to get a constant video signal into our machine. We were using the HDMI output of the Hero3 and converted it with Blackmagics HDMI->SDI Mini Converter and started the recording on the GoPro to get better video quality.
All we got was a flickering input signal in Vmix. We tried it with different HDMI and SDI cables, but it didn't work. We also tried the same setup with a prosumer camera and I got a clean signal with no flickering.
After googling for quite some time, I found out that it probably has something to do with GoPro and Mini Converter firmware/driver incompatibilities and that the Gopros HDMI signal has a RGB output format.
I tried different firmwares and drivers, but I've had always the same flickering problem.
So what's your trick? Which firmware/drivers do you use?
I just can't get it to work properly.
Rank:: Advanced Member
Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Is the GoPro compatible with PAL frame rates?
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
youtube could bite you in the bum if it detects copyrighted materials in live stream (and will not accept the fact that you licenced it I know from experience)
dutch internet isn't that bad price-wise, major problem with going 3g or 4g is that on a busy event you loose signal because a lot of people are using the same celltower. That's why we use our satlink at events with more than a few visitors.
M@ik
(We're a Dutch streaming media provider)
Brian Hazelden wrote:Is the GoPro compatible with PAL frame rates? Yes it is
Showcase
