 Joined: 7/4/2022(UTC) Posts: 1  Location: SeoulThanks: 1 timesWas thanked: 1 time(s) in 1 post(s)
                Hello
 I have a question about the recent issue.
 In the process of operating the broadcast from the main PC to vmix and YouTube streaming through external equipment,
 I used Input7, External_1 (Decklink Quad2 - Number 8 port)
 There was an issue that caused a slight noise in the audio.
 I changed the cable and setting after the streaming ended, but it didn't work out
 After moving the Device setting from Decklink No. 8 to No. 7 in the External setting, the problem is solved.
 This problem has occurred since the recent update.
 Please check.
 vMix is the best program.
 Thank you :)
              1 user thanked Conan.Kim for this useful post. |  |
                I have same problem..is there anyone can solve this issue?
