Joined: 7/4/2022(UTC) Posts: 1  Location: Seoul Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hello
I have a question about the recent issue.
In the process of operating the broadcast from the main PC to vmix and YouTube streaming through external equipment, I used Input7, External_1 (Decklink Quad2 - Number 8 port) There was an issue that caused a slight noise in the audio.
I changed the cable and setting after the streaming ended, but it didn't work out After moving the Device setting from Decklink No. 8 to No. 7 in the External setting, the problem is solved.
This problem has occurred since the recent update. Please check.
vMix is the best program. Thank you :)
 1 user thanked Conan.Kim for this useful post.
I have same problem.. is there anyone can solve this issue?
