Joined: 7/1/2022(UTC) Posts: 2  Location: Berkshire Thanks: 1 times
We're partially in to a vMix trial at work and loving it so far, so will definitely be purchasing. I have one issue that I can't seem to solve: - When using a virtual set and using the SetMultiViewOverlay shortcut to change one of the overlays inputs to different camera inputs, how do I get a nice fade transition instead of a hard cut, please? I hope this is possible.
Joined: 9/10/2015(UTC) Posts: 135  Thanks: 2 times Was thanked: 35 time(s) in 32 post(s)
For the multiview layers you can't transition. You'd need to use a 'Mix' input and then use that as your multiview layer. (There are only 2 things that can transition in vMix- overlays and mixes. Mix 1 is always program. Mixes 2-4 can be used for whatever you like. Also note that mixes 2-4 are only available on certain versions.) https://www.vmix.com/help25/index.htm?Mix.html
 1 user thanked paco3346 for this useful post.
Thank you Paco3346.. It's a shame there isn't just a simple fade option, maybe I'll submit a feature request. I'll have a play with the mix option, as you have suggested. Thanks again!!!
