99Problemos
#1 Posted : Friday, July 1, 2022 6:44:44 AM(UTC)
99Problemos
We're partially in to a vMix trial at work and loving it so far, so will definitely be purchasing.
I have one issue that I can't seem to solve: -
When using a virtual set and using the SetMultiViewOverlay shortcut to change one of the overlays inputs to different camera inputs, how do I get a nice fade transition instead of a hard cut, please? I hope this is possible.
paco3346
#2 Posted : Friday, July 1, 2022 8:01:08 AM(UTC)
paco3346
For the multiview layers you can't transition.
You'd need to use a 'Mix' input and then use that as your multiview layer.
(There are only 2 things that can transition in vMix- overlays and mixes. Mix 1 is always program. Mixes 2-4 can be used for whatever you like. Also note that mixes 2-4 are only available on certain versions.)
https://www.vmix.com/help25/index.htm?Mix.html
thanks 1 user thanked paco3346 for this useful post.
99Problemos on 7/1/2022(UTC)
99Problemos
#3 Posted : Friday, July 1, 2022 9:24:36 PM(UTC)
99Problemos
Thank you Paco3346.. It's a shame there isn't just a simple fade option, maybe I'll submit a feature request.
I'll have a play with the mix option, as you have suggested.
Thanks again!!!
Similar Topics
New vMix user, need help tweaking my system (General Discussion)
by Cpilcher 10/19/2015 4:10:01 AM(UTC)
