svetotehnik
#1 Posted: : Friday, June 17, 2022 2:09:29 AM(UTC)
svetotehnik
Russian Federation
There is a game, written on vb.net
You can use source code or just download .rar, import configuration and try it
Recommended font for score is Connection II
game v1.rar (34kb) downloaded 26 time(s).
Code:
dim xml_for_best as string = API.XML()
dim x_for_best as new system.xml.xmldocument
x_for_best.loadxml(xml_for_best)
dim last_best double = 0
dim Xbar as string = "0"
dim barXd as double = 0
dim WhatISX as double = 0
dim WhatISY as double = 0
dim angle as double = 1
dim dirX as int32 = 1
dim dirY as int32 = 1
dim score as double = 0
dim delay as double = 20
'check if there is a better score, if not, write 0
If Not ((x_for_best.SelectSingleNode("//dynamic/value2").InnerText) Is Nothing) Then
	dim best as int32 = 0
Else
	last_best = (x_for_best.SelectSingleNode("//dynamic/value2").InnerText)
End If
'put the racket on stop
API.Function("SetDynamicValue1", Value:="S")
'write 0 for score
API.Function("SetText", Input:="score.gtzip", SelectedIndex:="0", Value:=score)
While True
	dim xml as string = API.XML()
	x.loadxml(xml)
	'check the commands for the movement of the racket
	dim LRbar as string = (x.SelectSingleNode("//dynamic/value1").InnerText)
	If LRbar = "L" Then
		barXd=barXd-0.01
	End If
	If LRbar = "R" Then
		barXd=barXd+0.01
	End If
	'stop the racket if it reaches the edge of the screen
	If barXd < -0.839 Then
	End If
	If barXd > 0.839 Then
	End If
	'converting the data in suitable for API
	dim barXs as string = barXd.ToString
	If barXs.Contains(",") Then
    	barXs = barXs.Replace(",", ".")
	End If
	'racket movement
	API.Function("SetPanX", Input:="player_bar.png", SelectedIndex:="0", Value:=barXs)
	dim WhatXbarD as double = Xbar
	WhatISX=WhatISX-0.01*dirX
	WhatISY=WhatISY+0.01*dirY*angle
	If WhatISX < -0.954 Then
		dirX = -1
	End If
	If WhatISY > 1.662 Then
		dirY = -1
	End If
	If WhatISX > 0.954 Then
		dirX = 1
	End If
	If WhatISY < -0.001 Then
		'game over
		If barXd-0.176 > WhatISX
			dim last_best_d as double = Convert.ToDouble(last_best)
			If score > last_best_d Then
				API.Function("SetText", Input:="score.gtzip", SelectedIndex:="1", Value:=score)
				API.Function("SetDynamicValue2", Value:="score")
			End If
			API.Function("OverlayInput3In", Input:="game_over.png")
			API.Function("ScriptStopAll")
		ElseIf barXd+0.176 < WhatISX
			End If
		Else
			'score increment
			score = score+100
			If delay > 5 Then
				If LRbar = "L" and dirX = 1 Then
					angle = angle*1.2
				ElseIf LRbar = "L" and dirX = -1 Then
					angle = angle/1.3
				ElseIf LRbar = "R" and dirX = 1 Then
					angle = angle*1.4
				ElseIf LRbar = "R" and dirX = -1 Then
					angle = angle/1.1
				End If
				dirY = 1
				'speed increase
				delay = delay - 1
			Else
					angle = angle*1.2
					angle = angle/1.3
					angle = angle*1.4
					angle = angle/1.1
				End If
				dirY = 1
				'speed decrease
				delay = delay + 10
			End If
		End If
	End If
	dim WhatISXs as string = WhatISX.ToString
	dim WhatISYs as string = WhatISY.ToString
	If WhatISXs.Contains(",") Then
    		WhatISXs = WhatISXs.Replace(",", ".")
	End If
	If WhatISYs.Contains(",") Then
    		WhatISYs = WhatISYs.Replace(",", ".")
	End If
	'ball movement
	API.Function("SetPanX", Input:="ball.png", SelectedIndex:="0", Value:=WhatISXs)
	API.Function("SetPanY", Input:="ball.png", SelectedIndex:="0", Value:=WhatISYs)
sleep(delay)
End While
thanks 1 user thanked svetotehnik for this useful post.
ManuGG on 9/13/2023(UTC)
