Joined: 11/6/2020(UTC) Posts: 21  Location: Saint-Petersburg Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
There is a game, written on vb.net You can use source code or just download .rar, import configuration and try it Recommended font for score is Connection II  game v1.rar (34kb) downloaded 26 time(s).Code:dim xml_for_best as string = API.XML()
dim x_for_best as new system.xml.xmldocument
x_for_best.loadxml(xml_for_best)
dim last_best double = 0
dim Xbar as string = "0"
dim barXd as double = 0
dim WhatISX as double = 0
dim WhatISY as double = 0
dim angle as double = 1
dim dirX as int32 = 1
dim dirY as int32 = 1
dim score as double = 0
dim delay as double = 20
'check if there is a better score, if not, write 0
If Not ((x_for_best.SelectSingleNode("//dynamic/value2").InnerText) Is Nothing) Then
dim best as int32 = 0
Else
last_best = (x_for_best.SelectSingleNode("//dynamic/value2").InnerText)
End If
'put the racket on stop
API.Function("SetDynamicValue1", Value:="S")
'write 0 for score
API.Function("SetText", Input:="score.gtzip", SelectedIndex:="0", Value:=score)
While True
dim xml as string = API.XML()
x.loadxml(xml)
'check the commands for the movement of the racket
dim LRbar as string = (x.SelectSingleNode("//dynamic/value1").InnerText)
If LRbar = "L" Then
barXd=barXd-0.01
End If
If LRbar = "R" Then
barXd=barXd+0.01
End If
'stop the racket if it reaches the edge of the screen
If barXd < -0.839 Then
End If
If barXd > 0.839 Then
End If
'converting the data in suitable for API
dim barXs as string = barXd.ToString
If barXs.Contains(",") Then
barXs = barXs.Replace(",", ".")
End If
'racket movement
API.Function("SetPanX", Input:="player_bar.png", SelectedIndex:="0", Value:=barXs)
dim WhatXbarD as double = Xbar
WhatISX=WhatISX-0.01*dirX
WhatISY=WhatISY+0.01*dirY*angle
If WhatISX < -0.954 Then
dirX = -1
End If
If WhatISY > 1.662 Then
dirY = -1
End If
If WhatISX > 0.954 Then
dirX = 1
End If
If WhatISY < -0.001 Then
'game over
If barXd-0.176 > WhatISX
dim last_best_d as double = Convert.ToDouble(last_best)
If score > last_best_d Then
API.Function("SetText", Input:="score.gtzip", SelectedIndex:="1", Value:=score)
API.Function("SetDynamicValue2", Value:="score")
End If
API.Function("OverlayInput3In", Input:="game_over.png")
API.Function("ScriptStopAll")
ElseIf barXd+0.176 < WhatISX
End If
Else
'score increment
score = score+100
If delay > 5 Then
If LRbar = "L" and dirX = 1 Then
angle = angle*1.2
ElseIf LRbar = "L" and dirX = -1 Then
angle = angle/1.3
ElseIf LRbar = "R" and dirX = 1 Then
angle = angle*1.4
ElseIf LRbar = "R" and dirX = -1 Then
angle = angle/1.1
End If
dirY = 1
'speed increase
delay = delay - 1
Else
angle = angle*1.2
angle = angle/1.3
angle = angle*1.4
angle = angle/1.1
End If
dirY = 1
'speed decrease
delay = delay + 10
End If
End If
End If
dim WhatISXs as string = WhatISX.ToString
dim WhatISYs as string = WhatISY.ToString
If WhatISXs.Contains(",") Then
WhatISXs = WhatISXs.Replace(",", ".")
End If
If WhatISYs.Contains(",") Then
WhatISYs = WhatISYs.Replace(",", ".")
End If
'ball movement
API.Function("SetPanX", Input:="ball.png", SelectedIndex:="0", Value:=WhatISXs)
API.Function("SetPanY", Input:="ball.png", SelectedIndex:="0", Value:=WhatISYs)
sleep(delay)
End While
 1 user thanked svetotehnik for this useful post.
