Joined: 4/27/2018(UTC) Posts: 33   Location: Brazil Thanks: 408 times Was thanked: 19 time(s) in 8 post(s)
Hi Martin, Although vmix offers automatic portuguese translation from google but the brazilian portuguese language has several words and meanings different from portuguese (portugal). For this reason I am sending to you the Brazilian Portuguese translation file pt-BR 27.txt version 27. The ISO 639-1 standard does not list Brazilian Portuguese, but in most programs the pt-BR code is used. Eduardo Freitas vMix Brasil Reseller https://EasyStream.com.br pt-BR 27.txt (93kb) downloaded 22 time(s).Obs1: Para usar esta tradução Português Brasil, renomeie o arquivo para pt.txt e substitua no diretório C:\Program Files (x86)\vMix\languages) Obs2: Ao clicar no botão THANK você está contribuindo para que a tradução Português Brasil seja cada vez mais utilizada no vMix.
 12 users thanked eduardocfs for this useful post.
reustaquio on 6/9/2022(UTC), kison_erickson on 6/9/2022(UTC), Cascione on 6/10/2022(UTC), White on 8/31/2022(UTC), Sergio Marconi on 7/3/2023(UTC), fabianoafeque on 7/27/2023(UTC), leonardosfe on 8/23/2023(UTC), batistaigreja604 on 10/4/2023(UTC), eddysangalli on 11/23/2023(UTC), Edy Santos on 11/23/2023(UTC), TVCatolé on 2/16/2024(UTC), agentediego on 8/27/2024(UTC)
You have been a member since:: 10/4/2023(UTC) Posts: 1
Obrigado Eduardo, essa tradução será de grande valia para a equipe de multimídia da nossa igreja. Saberia dizer se funciona certinho na versão 26.0.0.45? Que Deus te abençoe.
 1 user thanked batistaigreja604 for this useful post.
Estaremos atualizando para o vMix 27. A tradução atual Funciona nas versões superiores sim. Ocorre que os novos termos das versões permanecerão em inglês mas a maioria dos termos serão traduzidos contextualizados.
 1 user thanked eduardocfs for this useful post.
Joined: 11/21/2023(UTC) Posts: 9  Location: Farroupilha/RS Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: eduardocfs  Hi Martin, Although vmix offers automatic portuguese translation from google but the brazilian portuguese language has several words and meanings different from portuguese (portugal). For this reason I am sending to you the Brazilian Portuguese translation file pt-BR.txt version 25.0.0.32. The ISO 639-1 standard does not list Brazilian Portuguese, but in most programs the pt-BR code is used. Eduardo Freitas vMix Brasil Reseller https://EasyStream.com.br pt-BR.txt (91kb) downloaded 41 time(s).Obs1: Para usar esta tradução Português Brasil, renomeie o arquivo para pt.txt e substitua no diretório C:\Program Files (x86)\vMix\languages) Obs2: Ao clicar no botão THANK você está contribuindo para que a tradução Português Brasil seja cada vez mais utilizada no vMix. We really need this attention, because the Brazilian vmix community is huge and there are translations that don't make any sense. The streaming button translates to something that looks like a small river. (LOL) pay extra attention to Brazilian members.
 1 user thanked eddysangalli for this useful post.
Joined: 5/19/2019(UTC) Posts: 5   Location: Araçatuba Thanks: 3 times Was thanked: 8 time(s) in 3 post(s)
Originally Posted by: eduardocfs  Hi Martin, Although vmix offers automatic portuguese translation from google but the brazilian portuguese language has several words and meanings different from portuguese (portugal). For this reason I am sending to you the Brazilian Portuguese translation file pt-BR.txt version 25.0.0.32. The ISO 639-1 standard does not list Brazilian Portuguese, but in most programs the pt-BR code is used. Eduardo Freitas vMix Brasil Reseller https://EasyStream.com.br pt-BR.txt (91kb) downloaded 41 time(s).Obs1: Para usar esta tradução Português Brasil, renomeie o arquivo para pt.txt e substitua no diretório C:\Program Files (x86)\vMix\languages) Obs2: Ao clicar no botão THANK você está contribuindo para que a tradução Português Brasil seja cada vez mais utilizada no vMix. +1
 1 user thanked Edy Santos for this useful post.
Olá Eduardo, Obrigado por fornecer o arquivo de tradução para o português brasileiro do vmix. Entendo a importância de ter traduções precisas e adaptadas às nuances específicas do português brasileiro. Vou renomear o arquivo para pt.txt e substituí-lo no diretório C:\Arquivos de Programas (x86)\vMix\idiomas. Sua contribuição certamente melhorará a experiência do usuário para falantes de português no Brasil, e agradeço seus esforços em promover o uso da tradução para o português brasileiro no vmix. Você também pode conferir o Spotify Plus. Brasil se refere a uma versão específica ou plano de assinatura do Spotify, mas você pode usá-lo gratuitamente no idioma brasileiro.
 1 user thanked Bryson Aria for this useful post.
Below is the version for vMix 28.0.0.42. The translation that comes with the original installation has over 1220 lines. Updated and fixed errors such as the high-performance entry mode flag, which requires checking if you have cards with more than 3GB of memory. However, with resizebar, you don't have to check it and there was no warning about it. In the translated version, it said to check it for cards with "only 3GB," when the correct version is only for cards with 3GB or more. Just replace the file in C:\Program Files (x86)\vMix\languages
Segue versão para o vMix 28.0.0.42 >>  pt.txt (94kb) downloaded 3 time(s).A tradução que vem na instalação original tem mais de 1220 linhas. Atualizado e corrigido erros como a flag do modo de alto desempenho de entrada, que manda marcar se tem placas com mais de 3GB de memoria. Porem com resizebar não tem que marcar e não tinha qualquer aviso sobre. Na versão de tradução ai, mandava marcar para placas com "apenas 3gb" sendo que o certo é apenas para placas com 3GB ou mais. Basta substituir o arquivo la em C:\Program Files (x86)\vMix\languages
