Systems
PC Bulid still on x299 or 12th Gen
Hello guys , we have an opportunity to create a PC and I'm not sure what would be the best option . For now we are using 2 BMD Duo 2 , but looking to upgrade to 4k in near future at least a part of the prod . due the lack of pci lanes (for 12th gen) as 8k pro require 8x
From Vmix reference systems on 4k + replay "Diamond" , it is recomended i9 10980XE (hard to find , also on many distribuitors x299 MOBO it is out of stock for a long time )
Did anybody already using the use 12th Gen CPUs with vMix? Any issues to look out for performance and stability ? Is still a good option the 10th Gen ? Due the need of pci lanes but it gets preatty old , I'm affraid just that Intel will move quickly and 10th gen will be obsoleted , now is hard to find some components for X-series I don't want to imagine what will be in one year.
My options are :
For 12th GEN Motherboard: ASUS ROG STRIX Z690-E GAMING WIFI Processor: Intel i9 12900KF Processor Cooling: ROG 360 RYUJIN II AIO LIQUID CPU COOLER RGB Memory: DDR5 64GB (4X16GB) 4000MHZ Graphics: NVIDIA RTX 3090 24GB GRAPHICS (BRAND MAY VARY) SSD: NVME M.2 SSD 2TB HDD: SEAGATE 2TB HDD 7200RPM Power Supply: 1000W 80 PLUS GOLD rate Fully Modular PSU Case: ASUS TUF GT501 ATX SERIES Capture cards : 2 x BMD Duo 2 , upgrade to 1 BDM 8k Pro + 1 Duo 2 OS: Windows 10 pro
For i9 10980XE Motherboard: ASUS ROG Strix X299-E Gaming II Processor: 10980XE Processor Cooling: Cooler Master MasterLiquid ML360R RGB Memory: DDR4 64GB (4X16GB) Graphics: Gigabyte GeForce RTX 3080 Ti Gaming OC 12GB SSD: SSD M.2 2TB SAMSUNG 980 PRO SDD: SSD M.2 500GB SAMSUNG 980 PRO Power Supply: Corsair RMx (2021) 850 W 80+ Case: NZXT H series H710i Capture cards : 2x Duo 2 future upgrade to 2x 8k pro OS: Windows 10 pro
Joined: 1/31/2017(UTC) Views messages in topic : 95 Location: KZ
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
I have 10980XE and recently compared it with my friends 12700k. Without 4Ghz oc, the new processor is faster. If you have good cooling and can pass beyond 4Ghz, then the 10980XE can keep up. Of course you would also have more cores and PCI lanes if that's important to you.
If I was in your position, I would have gone for a newer generation. They are better in price/permormance scale.
Systems
