ThRatte
#1 Posted : Monday, April 25, 2022 6:58:59 PM(UTC)
ThRatte
Germany
I have an Excel-File located on Microsoft One-Drive. This File ist connected to VMiX as Data-Source. If I change something in this file from another PC it takes something between 20-30 seconds to update the Data in VMIX.
When I close the file after I change something, the Update in VMIX will appear immediately.
Any Ideas how to get the update faster without closing the Excel-file?
Schönen Gruß
Thomas
thanks 1 user thanked ThRatte for this useful post.
meremultimedia on 4/25/2022(UTC)
#2 Posted : Monday, April 25, 2022 7:13:39 PM(UTC)
Schönen Gruß
Thomas
Maybe manually save the changes (not close)instead of waiting for a autosave
ThRatte
#3 Posted : Monday, April 25, 2022 7:15:51 PM(UTC)
ThRatte
Germany
saving the File does not work, only closing the Excel-File.
meremultimedia
#4 Posted : Monday, April 25, 2022 8:00:23 PM(UTC)
meremultimedia
Italy
+1
MEBROS
#5 Posted : Wednesday, April 27, 2022 4:03:24 PM(UTC)
MEBROS
Mexico
Schönen Gruß
Thomas
hola a todos si utilizar el documento Excel de forma WEB puedes hacer hacer cualquier cambio y después actualizar la pagina con F5 vas obtendrás su actualización en menos de 10 segundos
ThRatte
#6 Posted : Wednesday, April 27, 2022 4:51:48 PM(UTC)
ThRatte
Germany
Thanks for the answer, unfortunately that doesn't work reliably either. I think it's a one drive specific issue. For all Excel files that are on local hard drives or servers, the update works within 1 second after saving.
Schönen Gruß
Thomas
