GT
Data-Source Excel
Joined: 10/21/2021(UTC) Posts: 6  Was thanked: 1 time(s) in 1 post(s)
I have an Excel-File located on Microsoft One-Drive. This File ist connected to VMiX as Data-Source. If I change something in this file from another PC it takes something between 20-30 seconds to update the Data in VMIX.
When I close the file after I change something, the Update in VMIX will appear immediately.
Any Ideas how to get the update faster without closing the Excel-file?
Schönen Gruß Thomas
 1 user thanked ThRatte for this useful post.
Schönen Gruß Thomas Maybe manually save the changes (not close)instead of waiting for a autosave
saving the File does not work, only closing the Excel-File.
Joined: 10/22/2016(UTC) Posts: 25   Location: Lucca, Italy Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Joined: 11/13/2021(UTC) Posts: 1  Location: OBREGON SONORA
Schönen Gruß Thomas hola a todos si utilizar el documento Excel de forma WEB puedes hacer hacer cualquier cambio y después actualizar la pagina con F5 vas obtendrás su actualización en menos de 10 segundos
Originally Posted by: MEBROS  hola a todos si utilizar el documento Excel de forma WEB puedes hacer hacer cualquier cambio y después actualizar la pagina con F5 vas obtendrás su actualización en menos de 10 segundos
Thanks for the answer, unfortunately that doesn't work reliably either. I think it's a one drive specific issue. For all Excel files that are on local hard drives or servers, the update works within 1 second after saving. Schönen Gruß Thomas
GT
Data-Source Excel
