Web API SetText doesn't work
Joined: 3/26/2020(UTC) Posts: 19  Location: Utah Was thanked: 1 time(s) in 1 post(s)
I'm having trouble with the web api Set Text Function.
Here's the URL I'm using: http://localhost:8088/API/?Function=SetText&Input=Name&Title1=Another
(And yes... the input is called "Name" and the text field is called "Title1")
It responds with "Function completed successfully."
Even if I change the input and text field names to some bogus that doesn't exist, it still just responds with
I feel like there's something easy I'm overlooking here. Any ideas?
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
try:
http://localhost:8088/API/?Function=SetText&Input=Name&SelectedName=Title1&Value=Another
