No audio when adding Zoom Call to vMix
We have followed the directions in the KnowledgeBase to add a Zoom call to vMix with return audio and video. https://www.vmix.com/kno...-return-video-and-audio. We have video with no problems, but cannot hear anyone on the Zoom call. We have tried any number of different configurations to try and get it to work, but to no avail.
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Originally Posted by: RUCTech  We have followed the directions in the KnowledgeBase to add a Zoom call to vMix with return audio and video. https://www.vmix.com/kno...-return-video-and-audio. We have video with no problems, but cannot hear anyone on the Zoom call. We have tried any number of different configurations to try and get it to work, but to no avail. Hi RUCTech, Can you please clarify your setup to us? Is it 1 / 2 PC setup? How did you send the ZOOM Audio back to vMix? Thanks in advance.
We are using 2 PCs connected with vMix desktop Capture and NDI Webcam Input. and the problem is that we are not getting the Zoom audio back into vMix.
Joined: 6/27/2021(UTC) Posts: 43   Thanks: 50 times Was thanked: 4 time(s) in 4 post(s)
Where is Windows listening? Where is vMix listening?
Hi RUCTech,
Can you see ZOOM Screen in any Input of vMix? If you can see it, try to check if the Audio is enabled and it received Signal from ZOOM PC.
We can see the Zoom screen in vMix as an input. We have enabled the audio for that input, but are still unable to hear anyone on Zoom.
Joined: 11/15/2021(UTC) Posts: 84  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
Check Step 6 from the KnowledgeBase https://www.vmix.com/kno...-return-video-and-audio.check if your Zoom PC send Audio via ndi: Close vmix and open the ndi Monitor from NDI-Tools to check the Audio. If Audio don’t works with ndi Monitor the issue is on your Zoom pc. Else Check your Audio Routing on vmix
 1 user thanked Salvatore for this useful post.
