Janke
#1 Posted : Tuesday, April 5, 2022 11:32:24 PM(UTC)
Janke
Sweden
I just bought a Winvent HY-1650HD panel.
But can not find the drivers for the table. Does anyone have it? MVH // Janke from Sweden.
Mail to: info@janke.se
This dosent work! https://pan.baidu.com/s/13-FzjorIUzhSgwysbMymPw
JxM
#2 Posted : Friday, April 8, 2022 11:34:49 PM(UTC)
JxM
Yes, will send it to you.
Can you check later if your T-bar is working properly? We have an issue with t-bar only giving values 0-249 instead of 0-255.
Thanks!
DetoxX
#3 Posted : Saturday, April 9, 2022 12:33:43 AM(UTC)
DetoxX
Can you also post here also so we can also use with our setup
JxM
#4 Posted : Saturday, April 9, 2022 2:05:27 AM(UTC)
JxM
HY-1650HD.zip (31kb) downloaded 75 time(s).
Here it is. Just make sure to reember steps how to change language to English since it will change it to Chinese as soon as zou run the config file.
thanks 1 user thanked JxM for this useful post.
GregL on 11/17/2022(UTC)
Similar Topics
Winwet HY-1650HD .config file (Hardware Compatibility)
by JxM 2/24/2022 5:01:36 AM(UTC)
