Yes, will send it to you.
Can you check later if your T-bar is working properly? We have an issue with t-bar only giving values 0-249 instead of 0-255.
Thanks!
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Can you also post here also so we can also use with our setup
 HY-1650HD.zip (31kb) downloaded 74 time(s).Here it is. Just make sure to reember steps how to change language to English since it will change it to Chinese as soon as zou run the config file.
 1 user thanked JxM for this useful post.
