Dear Forum Members, i am figuring out how to patch the ouputs of an AJA IO X3 to vMIX. Inputs did work immediately but the output seams not to work. I installed all the drivers, i shut down the whole system repeatedly, switched on and off the X3 device and unplugged it with starting vMIX new.
In "Settings" - "External Output" i set the fourth channel to hdmi and sdi with the tick set on "External Renderer" but the maximum i´ve got is an purple screen on the external output.
Does anyone have an idea? I thank you very much. Fabian
- - - - - - - - - - Schenker DTR17 (E21) 1x 17.3" Ultra HD IPS | 100% Adobe-RGB | G-SYNC 1x NVIDIA GeForce RTX 3080 | 16 GB GDDR6 1x Intel Core i9-11900K 4x 8 GB (32 GB) DDR4-2933 Samsung 1x 2 TB M.2 Samsung 980 PRO | PCIe 4.0 x4 | NVMe 1x 500 GB M.2 Samsung 980 PRO | PCIe 4.0 x4 | NVMe
Running Win 10 Pro. All Drivers recently installed. All updates are installed vMIX MAX installed.
I think i can give myself the answer:
Output 1 is always SDI and HDMI but if Out 1 is in use then Input one is no more available
So you´ve got maximum 4 Streams that can be used either as In or Output.
So if I put Channel 3 to external output it doesn´t matter if i choose HDMI or SDI in the preferences of the external Outputs in vMIX. It will always be SDI.
If i choose one of the channels then the dedicated Connector is active. And at Output one (if it is not set up as input) then HDMI and SDI are active at the same time at the AJA-IO-X3. If you choose to take the channels 2 to 4 then the output is alway the dedicated SDI Connector. If you want to teke HDMI as input you are only allowed to do so if Output 1 is not active.
An addendum to this for clarity.
If you're outputting from the AJA IO X3 you need to use 'Output 1' option within Vmix. Output 2-4 appear as options but do not work (purple image as referenced above).
Doing so prevents use of Input 1, 2-4 unaffected.
