NotEugenio
#1 Posted : Wednesday, February 9, 2022 6:13:35 AM(UTC)
NotEugenio
Italy
Hello! I'm trying to get a h265 SRT stream to work as vmix input - however I just can't seem to pull it off.
I tested from both larix and obs, if I set the codec to h264 everything works, otherwise not.
It's ultra-weird as I have done this before. I tried both hardware and software encoders for both out and input.
Here's a video showing the issue
NotEugenio
#2 Posted : Thursday, February 17, 2022 2:34:56 AM(UTC)
NotEugenio
Italy
does anybody have any info about this? It is very much still happening!
#3 Posted : Thursday, February 17, 2022 2:59:29 AM(UTC)
Originally Posted by: NotEugenio Go to Quoted Post
Helpfiles:
When using HEVC on Windows 10, the "HEVC Video Extensions" from the Microsoft Store is required to be installed.
Did you ?
Proper port open ?
mgrayeb on 2/17/2022(UTC)
NotEugenio
#4 Posted : Thursday, February 17, 2022 3:43:55 AM(UTC)
NotEugenio
Italy
Helpfiles:
Did you ?
Proper port open ?
oh hehe
I did not have that codec no
But I had used vmix without it and it used to work! Weird! Anyway, buying that thing solved it for me. Thank you very much, you are a life saver!
A million treasures will come to you in the next life
stigaard
#5 Posted : Friday, February 18, 2022 7:21:00 PM(UTC)
stigaard
Denmark
oh hehe
I think the codecs can be retrieved and installed for free using the Microsoft store. Direct link: ms-windows-store://pdp/?ProductId=9n4wgh0z6vhq
Guest (5)
