alexg
#1 Posted : Friday, October 3, 2014 4:12:44 AM(UTC)
alexg
Using the basic HD version 14.0.0.80. I need to adjust the position of an input source slightly to centre the output so I am making use of the quick input change feature under the
general tab of input config so as to keep the adjusted settings. However, if I have all 4 inputs loaded and attempt to change any one of these then I'm told that the maximum number of inputs has been reached and I should upgrade. Has this been mentioned before?
Regards
Alex
#2 Posted : Friday, October 3, 2014 5:31:05 AM(UTC)
Hi Alex,
Thanks for reporting this bug.
I've just uploaded the 14.0.0.83 to the web site which fixes this issue.
http://www.vmix.com.au/download.aspx
