Using the basic HD version 14.0.0.80. I need to adjust the position of an input source slightly to centre the output so I am making use of the quick input change feature under the general tab of input config so as to keep the adjusted settings. However, if I have all 4 inputs loaded and attempt to change any one of these then I'm told that the maximum number of inputs has been reached and I should upgrade. Has this been mentioned before?
Regards Alex
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
