Slaver
#1 Posted : Wednesday, January 12, 2022 9:46:55 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hello Folks,
i have this problem for years but now the customer force me to solve this problem.
We get a stinger in mov format and use the video tool of vmix to create a png sequence for vmix. When i look into the mov file with vlc its smooth and has a good speed. In vmix the transition is much faster and not really good.
I there any chance to change speed? Ore has anyone the same problem and a solution?
Thank you!
JacobLarsson
#2 Posted : Wednesday, January 12, 2022 11:47:51 PM(UTC)
JacobLarsson
Norway
Are you using Interlaced/Progressive? We had the same issue, and I just duplicated and re-numbered all of the stills in the sequence and that solved it
thanks 1 user thanked JacobLarsson for this useful post.
Slaver on 1/12/2022(UTC)
Slaver
#3 Posted : Wednesday, January 12, 2022 11:52:17 PM(UTC)
Slaver
50i or 50p in both settings it is too fast.
Thank you for the interesting solution. I will give it a try.
