  Thanks: 27 times Was thanked: 8 time(s) in 8 post(s)
                Hello Folks,
  i have this problem for years but now the customer force me to solve this problem.
  We get a stinger in mov format and use the video tool of vmix to create a png sequence for vmix. When i look into the mov file with vlc its smooth and has a good speed. In vmix the transition is much faster and not really good.
  I there any chance to change speed? Ore has anyone the same problem and a solution?
  Thank you!
 Joined: 2/17/2021(UTC) Posts: 15  Location: Oslo Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
                Are you using Interlaced/Progressive? We had the same issue, and I just duplicated and re-numbered all of the stills in the sequence and that solved it
              1 user thanked JacobLarsson for this useful post.
                50i or 50p in both settings it is too fast.
  Thank you for the interesting solution. I will give it a try.
