Feature Requests
API entry "is Input actually present"
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
I would find an entry in the API very useful if an input above all a camera capture is actually present.
e.g. If you have two live inputs Main/BackUp it then would be possible to set up a small script, like: If Main Input fails (damaged connection, damaged output at X-Point, whatever...) send BackUp input to stream or recording or...
Wouldn´t it be possible to detect an input sync and state present/not present?
Feature Requests
