Javi
#1 Posted : Thursday, December 30, 2021 9:49:22 PM(UTC)
Javi
Spain
Hello. A bottom or function to delete a recent file that I don't want to keep should be REALLY USEFUL.
For instance, I'm recording myself doing several takes. I don't like one take and want to delete it immediately, before continuing recording. Having some button which deletes that last file/take without leaving vMix should be fine.
#2 Posted : Friday, December 31, 2021 1:24:22 AM(UTC)
Create a small vMix script to search for the last recorded file and delete it, can be called using a shortcut so you don't have to leave vMix ;-).
There is a scripting example in the knowledge base to just that if you change the if found function !
Javi on 12/31/2021(UTC)
