Feature Requests
Immediate and direct recorded file deletion function for the next take...
Joined: 12/30/2021(UTC) Posts: 2  Location: Madrid Thanks: 1 times
Hello. A bottom or function to delete a recent file that I don't want to keep should be REALLY USEFUL.
For instance, I'm recording myself doing several takes. I don't like one take and want to delete it immediately, before continuing recording. Having some button which deletes that last file/take without leaving vMix should be fine.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Create a small vMix script to search for the last recorded file and delete it, can be called using a shortcut so you don't have to leave vMix ;-).
There is a scripting example in the knowledge base to just that if you change the if found function !
Feature Requests
