Feature Requests
Photos input having the file names visible (maybe on hover?) to help cue/select live
You have been a member since:: 4/22/2017(UTC) Posts: 12 Location: Los Angeles, CA
Photos input is great to open and see all photos at once and then use your mouse to select and "fade" while hot on air, BUT a lot of times the file name is very important to help cue and locate photos from Producers. Is there any way to see the file name if you hover over a photo in the Photos input?
I would use Lists, but somehow Lists do not always show the proper aspect ratio of photos (jpeg and/or png). Apparently Lists are only for videos and music 🤷🏼♂️
Joined: 7/4/2021(UTC) Posts: 428  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: tsulls  Photos input is great to open and see all photos at once and then use your mouse to select and "fade" while hot on air, BUT a lot of times the file name is very important to help cue and locate photos from Producers. Is there any way to see the file name if you hover over a photo in the Photos input?
Thanks I don't know your particular use case, but if you can operate solely from the file name & you know them in advance, you can use a title & Date Source file to switch between them, in either manually or automatically.
Feature Requests
