tsulls
#1 Posted : Monday, December 27, 2021 6:30:44 AM(UTC)
tsulls
Photos input is great to open and see all photos at once and then use your mouse to select and "fade" while hot on air, BUT a lot of times the file name is very important to help cue and locate photos from Producers.
Is there any way to see the file name if you hover over a photo in the Photos input?
I would use Lists, but somehow Lists do not always show the proper aspect ratio of photos (jpeg and/or png). Apparently Lists are only for videos and music 🤷🏼‍♂️
WaltG12
#2 Posted : Saturday, January 8, 2022 12:41:23 PM(UTC)
WaltG12
I don't know your particular use case, but if you can operate solely from the file name & you know them in advance, you can use a title & Date Source file to switch between them, in either manually or automatically.
