rjwerth
#1 Posted : Thursday, December 23, 2021 7:15:14 AM(UTC)
rjwerth
I cannot get a smooth NDI stream out of VMix. Trying to output 1080p59.94 via any of the outputs. Constant skipping and stuttering. Testing using a Unifi switch between my vmix workstation and a laptop running Studio Monitor and/or a BirdDog Flex 4k Out.
If I run NDI screen capture on the Vmix workstation and send the Fullscreen monitor output while still running Vmix, I get no stuttering from the Screen Capture stream. So it isn't the computer or the network or anything outside of Vmix.
Please advise.
fluozh
#2 Posted : Thursday, December 23, 2021 12:41:02 PM(UTC)
fluozh
Japan
Did you try :
Disable QoS
Set Flow Control enabled
Disable Energy effecient ethernet and low-energy settingss
Set fixed bandwidth(1Gbps or 10Gbps, maybe 2.5G or 5G)
Set network "Private"
btw NDI Screen Capture send frame only when screen has motion/moving.(Sorry my English isnt good enough)
So I never got Screen Capture smooth. vMix <-> vMix is very stable though.
I have BirdDog's FLEX4KBP, Studio, and Magewell HDMI Plus with NETGEAR's M4250 switch so let me know if you want to test something!
Ryzen6667
#3 Posted : Monday, February 28, 2022 2:29:19 AM(UTC)
Ryzen6667
Netherlands
Unfortunately there are 1000000 tiny optimizations to be done on a system from network nic to bios.
But since you get it working pretty decently outside of vmix i suggest you manually update the NDI version in vmix.
This has resolved lots of issues for me on some systems.
https://www.vmix.com/kno...version-in-vmix-manually
melody
#4 Posted : Tuesday, April 5, 2022 7:58:01 PM(UTC)
Rank: Guest
Groups:
i had a similar problem before, 100mbit network isn't enough to deal with NDI... make sure if your network is 1Gbit
