eurofire
#1 Posted : Thursday, December 9, 2021 9:32:58 PM(UTC)
eurofire
Hi everyone, I'm trying to make a call with vmix, but i'm having some difficulty managing the audio of both.
The caller audio is good and clean for me, but he hears an annoying doubling of his voice. About me, I'm using headphones and microphone and I hear a little echo of my voice, not very marked, but I was wondering if it was possible to eliminate it
Thanks.
Chris Daum
#2 Posted : Monday, December 20, 2021 9:04:43 PM(UTC)
Chris Daum
Germany
which audio bus are you sending back to your caller?
on which audio bus are you receiving your caller?
where does the audio signal the caller is supposed to hear come from?
thanks 1 user thanked Chris Daum for this useful post.
eurofire on 12/22/2021(UTC)
eurofire
#3 Posted : Wednesday, December 22, 2021 11:13:45 PM(UTC)
eurofire
Thank you for your answer, actually I supposed I had to enable some buses but in this case I tought wasn't necessary. I need to record a video call, with an exernal host and me, using internal webcam and mic. How I need to set audio buses to avoid echo for both?
Chris Daum
#4 Posted : Thursday, December 23, 2021 6:07:06 AM(UTC)
Chris Daum
Germany
I would set up the following
Audio Busses
A - Recording
B - Return Bus for the callers
C - Listen Bus for your Headset (optional)
Call 1
AudioSource - B
Playout Bus - A, B, C(optional)
vMix doesn´t send back incoming call audio to its own bus
Headset
Playout Bus A,B
Listen Bus A (so you will hear yourself due to recording monitoring)
Listen Bus C (you won´t hear yourself, lacking complete recording monitoring)
If you use (M,A,B) you don´t have the possibility to only hear the callers,
cause when your headset is defined as "Headset" in audio output settings you will always hear M
over your headset
eurofire on 1/13/2022(UTC)
eurofire
#5 Posted : Thursday, January 13, 2022 2:02:23 AM(UTC)
eurofire
Thank you, you have been very kind and exhaustive, above all for that:
over your headset
Now all is clear
WaltG12
#6 Posted : Thursday, January 13, 2022 9:22:56 AM(UTC)
WaltG12
over your headset
But there's no rule that says you have to use the "Headphones" option for headphones.
Before they added the additional buses, I used it for a virtual cable.
After they added the additional buses, I set it to "None" and put my headphones on Bus C.
You can set your headphones to which ever output bus you want--you can even set them to multiple buses so all the audio flows to your headphones if you want.
Chris Daum
#7 Posted : Friday, January 14, 2022 8:36:24 AM(UTC)
Chris Daum
Germany
over your headset
Of course not
I usually work with all busses active D,E,F,G via Dante to Sound desk,
to be able to treat up to 4 Callers, as seperate audio channels in the desk, like each one
having his own mic
and most of the time work around M Bus
and having B,C As caller talk back and caller chat if required
A for my Headset
Similar Topics
Audio troubleshooting (General Discussion)
by dcb2125 6/29/2025 4:09:00 AM(UTC)
