RvE
#1 Posted : Sunday, November 21, 2021 11:03:09 PM(UTC)
RvE
Netherlands
As mentioned in the subject I am searching for a system that can do:
5x 4K NDI inputs
2x 1080 / 4K SDI inputs
1 or 2 Streams at 1080p
Iso recording of all 7 inputs and program out @ 4k. This must be Proress LT of H264/ H265 High quality. This will be used for Post production.
At least 2 HDMI/DP outputs. One for controlling VMIX and one Multiview for the cam operators. A 3rd PGM out @ 1080p would be nice
The system I have in mind is:
MB: ASUS WS X299 Sage/10G
CPU: Intel Core i9-10980XE
RAM: 32 or 64 GB
GPU: PNY Quadro RTX 6000 24gb
HDD: 2x Samsung 980 Pro 2TB. (unfortunately no raid is possible at the M2 slots on this MB)
And a 2,5inch U2 SSD 3,2 TB + a regular SSD for the OS.
The MB has 2 10gb NIC. 1 will be used voor NDI and the second one for acces to the internet.
The system wil be controlled with a Skaarhoj Air Fly Pro.
Some overlay's and title bars will be used but nothing fancy.
Is this possible or am I aiming too high?
For now 4k is not necessary but the cam's can do 4K so why not use it :-)
Greatings,
RvE
TomZhang
#2 Posted : Friday, June 24, 2022 7:01:14 PM(UTC)
TomZhang
China
Hi,do you work it out? the same problem with me。
