Hardware Compatibility
Big system for 5xNDI 4K + 2xSDI + 1080p Stream + ISO recording
As mentioned in the subject I am searching for a system that can do: 5x 4K NDI inputs 2x 1080 / 4K SDI inputs 1 or 2 Streams at 1080p Iso recording of all 7 inputs and program out @ 4k. This must be Proress LT of H264/ H265 High quality. This will be used for Post production.
At least 2 HDMI/DP outputs. One for controlling VMIX and one Multiview for the cam operators. A 3rd PGM out @ 1080p would be nice
The system I have in mind is:
MB: ASUS WS X299 Sage/10G CPU: Intel Core i9-10980XE RAM: 32 or 64 GB GPU: PNY Quadro RTX 6000 24gb HDD: 2x Samsung 980 Pro 2TB. (unfortunately no raid is possible at the M2 slots on this MB) And a 2,5inch U2 SSD 3,2 TB + a regular SSD for the OS.
The MB has 2 10gb NIC. 1 will be used voor NDI and the second one for acces to the internet. The system wil be controlled with a Skaarhoj Air Fly Pro.
Some overlay's and title bars will be used but nothing fancy.
Is this possible or am I aiming too high? For now 4k is not necessary but the cam's can do 4K so why not use it :-)
Greatings,
RvE
Hi,do you work it out? the same problem with me。
