Johnkendall
#1 Posted : Wednesday, November 17, 2021 12:51:13 AM(UTC)
Johnkendall
My apologies if this has been asked before, my google-ing skills have failed me.
I'm trying to work out how to build a script to set the Audio Busses for a given input. Can anyone point me in the right direction.
Basically, I want two scripts.
Script 1 sets Input 1 to Buses A and B only
Script 2 sets Input 1 to Buses C and D only.
John
#2 Posted : Wednesday, November 17, 2021 5:34:33 AM(UTC)
John
Functions used in a script are the same as if you would use them in a shortcut
Is a good idea to look there for more details first regarding a function
The helpfiles also have the complete list of available functions
Can do it with just shortcuts instead of script
Check the functions Audiobus with value the Bus
Chris Daum
#3 Posted : Sunday, November 21, 2021 7:35:58 AM(UTC)
Chris Daum
Germany
You could do something like:
Code:
dim BusL1() As String = {"a","b"}
dim BusL2() As String = {"c","d"}
for i as Integer = 0 to 1
api.function("AudioBusOn", input:=1, value:=BusL1(i))
api.function("AudioBusOff", input:=1, value:=BusL2(i))
next
and vice versa
