Scripting - Set Audio buses on an input
Joined: 11/6/2020(UTC) Posts: 5  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
My apologies if this has been asked before, my google-ing skills have failed me. I'm trying to work out how to build a script to set the Audio Busses for a given input. Can anyone point me in the right direction.
Basically, I want two scripts. Script 1 sets Input 1 to Buses A and B only Script 2 sets Input 1 to Buses C and D only.
Thanks John
Originally Posted by: Johnkendall  My apologies if this has been asked before, my google-ing skills have failed me. I'm trying to work out how to build a script to set the Audio Busses for a given input. Can anyone point me in the right direction.
Thanks John Functions used in a script are the same as if you would use them in a shortcut Is a good idea to look there for more details first regarding a function The helpfiles also have the complete list of available functions Can do it with just shortcuts instead of script Check the functions Audiobus with value the Bus
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
You could do something like: Code:dim BusL1() As String = {"a","b"}
dim BusL2() As String = {"c","d"}
for i as Integer = 0 to 1
api.function("AudioBusOn", input:=1, value:=BusL1(i))
api.function("AudioBusOff", input:=1, value:=BusL2(i))
next
and vice versa
