MartLeib
#1 Posted : Friday, November 12, 2021 5:06:41 PM(UTC)
MartLeib
Estonia
I am unable to find a shortcut (function) to reload GT input. Functionally that is like right-clicking on a title and then Reload.
I am using vMix and GT in TV production as a graphics machine for one of my clients with about 25 GT titles and sometimes we need to reload them since if the image file (logo) changes in the Data Source before the event, it does not update in vMix (because the filename is the same as old image), reloading the title pulls a new version of the image nicely.
Also, having a function would be beneficial in the development process, we could set up automatic reloading of title to see the title in action on vMix while making changes in GT Title Designer.
#2 Posted : Friday, November 12, 2021 7:18:24 PM(UTC)
Reloading a title also starts transitionIn animations
(Until available):
one can achieve this with Set image function ( in script called by shortcut)
What about if the script that looks for the saved time change of the image and sets the image in response automatically? (checked and does it without animations)
TL68
#3 Posted : Thursday, December 21, 2023 7:26:01 PM(UTC)
TL68
Sweden
+1 on this request! With the option to reload a specific title by number or all titles.
Usecase: we use sheets as data source for text and image paths in titles and sometimes updates in the sheet doc doesn´t come through without a reload.
Since we like to run vMix by a Streamdeck a button called something like "update all graphics", running title reloads shortcuts to use before a broadcast would be very handy.
monamiga
#4 Posted : Saturday, June 29, 2024 6:06:06 PM(UTC)
monamiga
Philippines
+1 very important to me
#5 Posted : Saturday, June 29, 2024 7:29:52 PM(UTC)
Again before such option is available.
Most often the title not updating is due to different image but with same filename or a EMpty text in the datasource etc
A title checks for changes in filename or textdata (or ignores when empty/not available)
A potentual solution in the mean time would be to fill the parts with different data/file and fill back with "original"
Easely doable with a small "Reload" script.
A Variation would be to check the info of the title input, deleted it, load it as new and reposition it in its original place
Even better might be to delete the title input and use the "undo" function (might trigger an update)
EDIT: Even better IS to "RemoveInput" the title input followed with the "Undo" function
monamiga on 9/16/2024(UTC)
Fernado
#6 Posted : Tuesday, June 10, 2025 7:09:23 AM(UTC)
Fernado
Argentina
Hi everyone, I was having the same problem, I think i found a solution. The "ResetInput" function is the same as the Reload button in vmix, so i made a little script to reload all the graphics:
Code:
'First we load our xml as always
dim xml = API.XML()
x.loadxml(xml)
'Then we count all our inputs
dim totalinputs as integer = (x.SelectSingleNode("//input[last()]/@number").Value)
'we use that number to run a loop
'first line is to convert the number to string so we can use it in our xpath
'then we get the type of every input, if is "GT", then we use ResetInput in that input.
for inp as integer = 1 to totalinputs
	dim inpstring as string = inp.tostring
	dim checktitle as string = (x.SelectSingleNode("//input[@number=" + inpstring + "]/@type").InnerText)
	if checktitle = "GT"
		API.Function("ResetInput", Input:=inp)
	End If
next
I know its and old thread, but I found it googling for a solution for this, so hope it helps!
thanks 1 user thanked Fernado for this useful post.
TL68 on 4/27/2026(UTC)
TL68
#7 Posted : Monday, April 27, 2026 10:12:19 PM(UTC)
TL68
Sweden
Fernando, you saved my day!
After updating vMix to latest 29-version the random problems with my titles not updating with data from a sheets used as data source, and sometimes even going blank reoccured.
Of course a right click+reload on the GT title input fixed this on individual inputs. But tooo many clicks to fix an entire project. And still no shortcut or api-function to Reload.
Revisited this old thread and found Fernandos script which is exactly what I need. Now I can program companion/streamdeck to reload all titles with a simple press of a button!
I can also confirm that "Reset input" also work on individual GT Titles objects with an api-call like:
http://127.0.0.1:8088/api?Function=ResetInput&input=5
Still not sure if reset and reload does the same thing on a GT-title but hey, as long as it works for me :-)...!
TL68
#8 Posted : Tuesday, April 28, 2026 9:55:25 PM(UTC)
TL68
Sweden
Noticed that the script resetting all inputs did not work that well with a running scoreboard. So now I am running a script with individual lines for each input I want to be able to reset.
A bit more work but gives good control over things. So the script looks like this:
dim xml = API.XML()
x.loadxml(xml)
API.Function("ResetInput", Input:="inputname1")
API.Function("ResetInput", Input:="inputname2")
API.Function("ResetInput", Input:="inputname3")
API.Function("ResetInput", Input:="inputname4")
