Hi all, new vmix user here. We have this to use for our school live streams, mainly sports. The site we use to stream on provides a simple scoreboard that my students are familiar with. It open as any tab in a browser. I was wondering how I can add an input as just a screen recording of this tab and my student running the stream can not only edit the scoreboard, but also run Vmix at the same time, on the same laptop. Any help would mean a lot.
Thanks!
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Most simple just add the scoreboard as a webpage. A bit more advanced is using the scorboard data as a datasource in a dynamic XML for example and build a title that uses these data.
I tried a webpage and that's unavailable due to the fact that I have to log into their website in order to use the scoreboard. When the page loads in Vmix it shows the log in screen. Is there any way to screen capture and use that, similar to wirecast?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
When viewing a web page input in the program window Right click on the program window and enable both the mouse and the keyboard. this way you can navigate the web page while it’s in the program window, enter the login credentials for the site and so forth as if you were simply viewing the page in a browser.
OK so that helped a ton! I'm logged into the site now. The next issue is that for me to open the scoreboard it opens a new tab normally, but it cannot do that inside of the Vmix browser. Originally Posted by: AlanZ  When viewing a web page input in the program window Right click on the program window and enable both the mouse and the keyboard. this way you can navigate the web page while it’s in the program window, enter the login credentials for the site and so forth as if you were simply viewing the page in a browser.
Originally Posted by: levi.loofe  OK so that helped a ton! I'm logged into the site now. The next issue is that for me to open the scoreboard it opens a new tab normally, but it cannot do that inside of the Vmix browser.
Why not consider the page as regular and do a desktop capture , probably easier to work on that page that way too
