levi.loofe
#1 Posted : Friday, November 12, 2021 2:46:07 AM(UTC)
levi.loofe
Hi all, new vmix user here. We have this to use for our school live streams, mainly sports. The site we use to stream on provides a simple scoreboard that my students are familiar with. It open as any tab in a browser. I was wondering how I can add an input as just a screen recording of this tab and my student running the stream can not only edit the scoreboard, but also run Vmix at the same time, on the same laptop. Any help would mean a lot.
Thanks!
mavik
#2 Posted : Friday, November 12, 2021 3:18:12 AM(UTC)
mavik
Most simple just add the scoreboard as a webpage.
A bit more advanced is using the scorboard data as a datasource in a dynamic XML for example and build a title that uses these data.
levi.loofe
#3 Posted : Saturday, November 13, 2021 12:11:45 AM(UTC)
levi.loofe
I tried a webpage and that's unavailable due to the fact that I have to log into their website in order to use the scoreboard. When the page loads in Vmix it shows the log in screen. Is there any way to screen capture and use that, similar to wirecast?
AlanZ
#4 Posted : Saturday, November 13, 2021 8:53:39 AM(UTC)
AlanZ
When viewing a web page input in the program window
Right click on the program window and enable both the mouse and the keyboard.
this way you can navigate the web page while it’s in the program window, enter the login credentials for the site and so forth as if you were simply viewing the page in a browser.
levi.loofe
#5 Posted : Wednesday, November 17, 2021 1:01:52 AM(UTC)
levi.loofe
OK so that helped a ton! I'm logged into the site now. The next issue is that for me to open the scoreboard it opens a new tab normally, but it cannot do that inside of the Vmix browser.
#6 Posted : Wednesday, November 17, 2021 5:41:41 AM(UTC)
Why not consider the page as regular and do a desktop capture , probably easier to work on that page that way too
Similar Topics
How Do I Use Vmix to make Screen Recording Video with Picture Overlay? (General Discussion)
by Emmynet 1/2/2020 7:47:36 AM(UTC)
Difference in quality normal full screen and screen recording in 1920 X1080 (General Discussion)
by parag_ca 2/17/2015 8:45:10 AM(UTC)
