gahan
#1 Posted : Thursday, September 25, 2014 2:57:33 AM(UTC)
gahan
Hello
Why Vmix output varies 25, 26 fps.
We need 25fps output always.
Ivan Videv
#2 Posted : Thursday, September 25, 2014 3:10:33 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
The FPS timer at the bottom of vMix is a guide only. The real frames per second is whatever you set in vMix settings.
gahan
#3 Posted : Thursday, September 25, 2014 3:21:11 AM(UTC)
gahan
FPS timer at the bottom shows exact the same, as FMLE sees as input, so I think it shows real FPS
so real output in not stable 25 fps
Ivan
#4 Posted : Thursday, September 25, 2014 3:28:04 AM(UTC)
This is not true, both FMLE and vMix show an average FPS indicator which may
be slight above or slightly below 25fps depending on what the system is doing, but the final stream or recording will be exactly 25fps.
